- Jul 8, 2020
- 221
- Vinyl
- Intex Krystal Clear
It's cloudy and rainy if it matters, but I can add the stabilizer. Do I add it after getting the FC to my target? Then put the salt in?
Poolmath is in UTC. So no need to try and match the times. We are working on that aspect of the app (as it is used worldwide).Now how to get my times to match?
At what stage in the pool maintenance process are you? If you have a SWCG , you need to get your CYA to 70 ppm if the water is clear. Lower the ph to 7.4. Are you adding chlorine? You should never let your FC get that low.New test results posted. Looks like I should add bleach and little more CYA. What about the MA?
