I filled our new pool a little over a month ago. I am loving the TFP system! It is some easy pool maintenance. Since my pool is 24' AGP I wasn't worried about calcium. Just for giggles, I checked it the other day. It's 1100! Thinking I messed it up, I tested it again, same 1100. So, I tested the tap water, yep, 1100. I knew we had hard water, the scale will plug faucets up in just a few years, and toilets don't last much longer. But dang! So, I ran the saturation index in the Taylor kit and am sitting at 0.4 and flirting with 0.5 because the wife likes to keep the pool bath water warm UGH! At least that's the best I can estimate because the balance calculator only goes up to 1000 calcium. Here's my numbers:
pH 7.4
TA 90
CYA 40
FC 6
CC 0
calcium 1100
Edited to add: I checked the water temp with my digital thermometer. 89° O.M.G.
I'm afraid if the wife heats it up any more it's going to go cloudy (if it doesn't start boiling first, I should buy her a hot tub). I am considering dropping the pH to 7.2 to buy me a little more room. Is there anything else I can do? The water looks so beautiful and clear. I want it to stay that way.
pH 7.4
TA 90
CYA 40
FC 6
CC 0
calcium 1100
