- Jul 21, 2013
- 66,208
- Plaster
- Pentair Intellichlor IC-60
Builders often have different ideas about startup chemistry than the plaster manufacturer. There are different ways of doing plaster startup and most of them work out fine.
We prefer higher pH and TA that keeps the CSI positive.
The normal CSI guidelines are not applicable to new plaster finishes under 30 days old. It is actually necessary, to achieve a smooth and dense surface, to have about a +0.5 CSI during the first 30 days. This is because the plaster (cement paste) surface contains about 20% calcium hydroxide, which is somewhat soluble in balanced and slightly positive CSI water and can be dissolved away. The plaster surface needs to be "carbonated" before the CSI should be lowered to the acceptable and balanced range. And that generally is achieved during the first month under balanced water.
From Plaster Installation and Maintenance - Further Reading
Why no wheeled cleaner for first 30 days? Plaster is sufficiently hard once the pool is full of water. Pool cleaners can be installed and utilized after about two days if there is no plaster dust forming. The reason that tracks develop is usually from plaster dust being "packed down" by the pool cleaner wheels and then not removed by brushing. So it can look like an "indention" (and discolored) but it is not an indention. Brushing afterwards can help prevent the plaster dust from sticking on the plaster.
Really you should run the pump continuously until you no longer see plaster dust when doing your daily brushing. That could be 48 hours or 5 days or longer.
Running the pump continuously is all about getting the plaster dust filtered out of the water and not letting it settle on pool surfaces.
Understand why you are being told to do things and it should become clearer what to do.
Pebbletec company recommends really low pH levels for first 28 days. My pool builder instructions say differently 7.4-7.8).
Of note, my pool builder said I should have my suction side cleaner (that has wheels) going from day 1. Pebbletec instructions say no.
Pool builder said pump needed running for first 48 hours continuously, pebbletec instructions say 5 days.
Not sure what to do.
