This is my first post to TFP. I've read many of the forums and have found them really helpful, but I have a unique situation that I wanted to ask the forum about.
We live in San Antonio and bought a house with a pool in June. It's a typical spa/pool combo (gunite) that was built in 2010. We have two pumps - a brand new IntelliFlo VS pump that we had installed when we first bought the house, and a separate pump for a waterfall that isn't connected to the filter system or to the spa.
A few weeks ago, I noticed that the spa was draining to the level of the spa jets (which is roughly the same level as the pool) whenever the filter pump was on low speed (1100 rpm), the filter pump was off, or the system was in spa mode. The only time there wasn't an issue is when the filter pump was on high speed (2500 rpm).
After reading some of the forums on TFP and talking with the pool service company I've been using, we had every check valve in our system completely replaced. We also decided to hire a leak detection company to have a thorough inspection done. The leak detection company tested every valve, drain, and jet in the pool and didn't find any leaks. They did find that one of the actuator/diverter valves was busted (see the picture), so we had a pool service company come to install a new one.
Once the check valves were replaced and the new actuator/diverter valve was installed, we stopped losing water in spa mode and we were losing only minimal water in low speed - but the water in the spa goes down significantly, and quickly, whenever the filter pump is off.
We have the following valves (from left to right):
-Spa jet return (check valve installed) - this is the line that returns water to the spa in spa mode
-Spa main drain suction
-Pool deep end skimmer
-Pool shallow end skimmer
-Pool main drain
-Pool return
-Spa return (check valve installed) - this is the line that returns water to the spa in pool mode
Shutting off the spa return valve doesn’t prevent the spa from losing water when the filter is off. To me, that indicates that the issue isn't with the spa return valve, which has a new check valve installed and seems to be doing its job by preventing water from going back to the pool via the spa return.
I also don't see how water can be coming back up through the spa jet return, since there is a new check valve installed there and also an actuator valve that closes that spa jet returns except for when spa mode is on.
The only plausible explanation that I can think of is that water is always getting through the spa main drain even when the actuator valve is switched to the “off” position - and this is despite the new actuator/diverter valve that was just installed. The actuator/diverter valve is probably letting in some water from the spa main drain all of the time. We just don’t notice it when the pump is running on high speed because more water is going back into the spa than is leaving through the spa main drain – so we don’t lose water in high speed. But if the pump is off, water continues to leave through the spa main drain, finds its way to the pool, and the spa level goes down because no new water is coming in.
Do you have any ideas or suggestions on what we could do next? I was thinking of having the pool service company come back to double check that the new actuator/diverter valve that they installed is correctly aligned. It seems to me like it's not exactly 100% flush with the plumbing, but it's hard to say.
Do you think they might need to cut open the pipes and install a new three-way valve into which the new actuator/diverter can be inserted?
I'm pretty stumped and really appreciate any advice or thoughts that you have! Thank you!
-Pool main drain
-Pool return
