Welcome to the forum. In general, larger pipe is always better but there are other factors that may have a much larger impact on jet performance.
Please describe the entire design:
  • Distance from pump to spa
  • Pipe size used for suction and return lines back to pump
  • Number of spa jets
  • Spa jet nozzle orifice diameter
  • Elevation difference between spa water level and the pump
  • Pump make/model used for the jets
Also, there are a couple of ways to plumb a spa/jet system.
Higher performance configuration:
Lower performance configuration:
Also, a blower is not always necessary if the spa is designed properly. Unless the spa plumbing runs uphill to the pump, a Hartford loop is usually necessary near the spa to make sure the air pipe does not fill with water. Otherwise a blower is required to clear the air line when the jets are started.
