- Jul 21, 2013
- 65,658
- Plaster
- Pentair Intellichlor IC-60
Refer to pic below..
Yellow actuator is for your sconces. Irrelevant for this discussion.
Red actuator is for your POOL or SPA suction. Spa pipes are on the left. Pool pipes are on the right. Spa pipe is OFF in picture.
Green actuator is for your cleaner and on spa side of return water flow. It only gets water when spa gets water.
Blue actuator is your POOL or SPA water return valve. Spa and cleaner pipes are to the left. Pool return water pipe is to the right. Spa and cleaner water is OFF in the pic. Spa spillover should not be running.
Red and blue actuators and valves should rotate when moving between POOL mode and SPA mode.
