Spa draining. I've checked all of the usual suspects
rxman
63
My spa has recently started draining when the pump is off. When the pump is on the spa has a spillover which functions as expected.
I have two Jandy valves with actuators which move for pool mode or spa mode. I removed the actuators and manually moved the valves to ensure they were in closed position. I opened the actual valves and inspected them for debris, cracks, broken rings etc.. I found nothing. I also have a check valve which I originally thought might be the culprit. I replaced the flap and spring.
Spa still drains. Any idea how to proceed? Thanks
Plettschner
262
Connecticut
How fast is it draining and can you tell if it's draining back to the pool?
rxman
63
It drains slowly. Maybe goes down an inch or so in an hour. Not sure if it goes back into pool or not.
rxman
63
I do have a Paramount In-floor cleaning system. According to the manual there is a check valve between the cleaning canister and the spa.
In my case this would be buried underground in a flower bed. It would be a pain to dig up, but I may do it.
mknauss
43,670
Laughlin, NV
Fiberglass
Pentair Intellichlor IC-40
Can you plug the in floor port in the spa?
rxman
63
I cannot plug a floor port.
I have replaced the check valve and also the insides of both Jandy valves. It’s still draining. No clue what to even try next. It drains down to the jets but not past. F06949BB-47C0-47E8-9DE6-ABB92E52B6A5.jpegED300C47-F40D-4F91-9718-D7FF61F8FD2B.jpeg
mknauss
43,670
Laughlin, NV
Fiberglass
Can you post pictures of your equipment pad? Focus on return lines, etc. Let us know what mode you have the valves set for when the pictures are taken.
Reactions: KellyAH
rxman
63
mknauss
43,670
Laughlin, NV
Fiberglass
Maybe pan back a bit? I am looking for the make up line for your spa. The line that sends water to it when your in pool mode.
rxman
63
That’s the first jandy valve pic. Pool return sends water through the floor cleaner which has a station in the spa.
mknauss
43,670
Laughlin, NV
Fiberglass
Might add you have an in floor cleaner in your signature.
The cleaner valve thing should have a check valve in it. Has that been checked?
rxman
63
mknauss
43,670
Laughlin, NV
Fiberglass
If you believe it is the spa jet side leaking back, then you should get a rebuild kit for the Jandy valve and pull it apart. I would not pull it apart until you get the rebuild kit.
rxman
63
I believe there may be a check valve on the floor cleaner but it’s buried underground. I semi attempted to dig it up but can try again. I thought if it was leaking through the cleaner then the level would be lower. Maybe not?
rxman
63
I have received the parts and rebuilt both Jandy valves. Still draining.
mknauss
43,670
Laughlin, NV
Fiberglass
Well, you have a dilemma. You are right, if you pool water level is still lower than the level it is currently draining to, then it would not be in floor thing.
I assume the spa runs fine when you move the Jandy valve for that to happen.
