- May 3, 2014
- 62,732
- Fiberglass
- Pentair Intellichlor IC-40
If your feed can be balanced by the pump, 600 gph divided into 15000 gallons. 25 hours.
PoolGate. Not sure I follow? I'm attempting an exchange so the walls won't be exposed.
You can safely swim in a pool as long as the FC is above the minimum and at or below SLAM level based on your CYA. You must also be able to see the bottom of the pool in the deep end of the pool.Is the pool safe to swim in with these chemical levels if I don’t get to this until next week?
