Hi Pool People!
New member and pool owner here. I have an in ground pool that came with a solar pool heater. I had a pool guy turn it on for me but he ended up being kind of unreliable so I ended up discontinuing his services and decided to do the pool myself using this forum. So far all of that has worked out really well. My question now is I am closing up my pool (covering). I wanted to shut off the solar heater so that I can lower the pool pump speeds but I am not sure how. I posted a few pictures of my set up. The main picture is numbered 1-5. Number 1 is currently shut off but I am not sure if I need to shut off additional valves in order for water to stop going up the pipes to the panels or if that is all that is needed. Just for reference I posted a pic of the pump that leads to the roof from the pump. Its the black pipe or #5 in the main picture. Please let me know if more info or pics are needed. Can anyone tell by looking at the pictures what should be done to completely stop water from going up to the panels and only from pump to pool? Thank you all!
