Hello all,
I have started getting discoloration on the pool surface. It is a slow process and it seems like the surfaces where the water flows are affected. On the stairs and on the sidewalls of the spa.
The pool company decided it is some kind of metal and we don’t know how metal got into the water. They asked me to but metal free. They used that.
Now I noticed the metal around the pool lights are getting dark. There is a black coat on the metal or it is rusting. I cannot tell.
Generally the only recurring issue is that the calcium levels get high. They can get as high as 500. At that point I empty the pool 1/3 or so and add fresh water. However tap water here has high calcium as well.
I just had pinch a penny test the water. Calcium at 500, and all other readings are a little off. The usual stuff.
This is a salt water pool with spa and a gas heater.
What could be causing this? Any ideas? Recommended actions?
Thank you.
Thank you.
