I’ve noticed the water in my pool is fairly cloudy. There’s a little fungal activity - a single brush down the vinyl each time I use it keeps it from being slimy, nothing visible.
Chemical balance is fine from all I’ve measured. Circulation moving fine, although filter is stubbornly slimey; I have a single inlet jet, I can see by the turbulance it’s hitting the far side. Tried cleaning filter using both 15% bleach and hydrochloric acid on it (not at the same time!!!).
Should I be looking at a (chlorine) shock and then clearing with sodium thiosulphate, or should I be changing filters? Filters are likely to be expensive as I’m in the UK and the part will be from the US
FC 0.75
CC 0
pH 7.4
CYA 0
TA 40-50
CH 300-350
FC 0.75
CC 0
pH 7.4
CYA 0
TA 40-50
CH 300-350
