Still trying to locate impeller, but no luck. Quesstion - can SPX4020CKIT be used instead of SPX4015CKIT? the difference is 1/16", but the actual size seems to be the same, unless dimensions on the pictures are wrong.
My new motor is - A.O. Smith Century 2.0 HP Round Flange 56J Up Rate Motor - UST1202 - INYOPools.com
My original motor (according to inyopools) is - A.O. Smith Century 2.0 HP Up Rated NorthStar Replacement Motor - USN1202 - INYOPools.com
The actual pictures from both motors are attached
I thought both motors are Up Rated, but I don't see it saying that on UST1202. According to Hayward rep these motors are not up rated not max rated, but real 2HP motors which would mean SPX4020CKIT can be used. But, I don't know if I cna trust Hayward customer reps, they've been wrong at least twice in the past.
If SPX4020CKIT can be used, which shaft seal should be used, SPX3200SA or SPX4000SA2? It looks like shaft seals are the same size, not sure what the difference is.
Thanks
Thanks
