Hi Guys!
I have a Hayward EC50 DE filter and 1.5HP Hayward Matrix Pump. The hose from my skimmer to my pump failed over night and my pump ran dry - I'm not sure exactly how long but could have been up to 4 hours. I replaced the hose and filled the pool. Now I'm getting a leak under the pump. Also, my filter pressure is very low and my pump isn't fully priming. It usually runs around 13psi and now is running at only 8psi. I searched and it seems that I should replace the shaft seal, but I'm not sure if there is other things I should be checking? Could the shaft seal cause the low water pressure and priming issue?
