- Jul 21, 2013
- 65,118
- Plaster
- Pentair Intellichlor IC-60
I looked at your pictures. Is the pump running?
The filter pressure gauge reads 10 psi. If the pump is off the pressure should be 0. If the pump is off and the gauge is not 0 then the gauge is broken.
it does not look like water is flowing through your clear SWG.
You need to look in the skimmers and see if they are plugged. You need to find the circuit breakers for the pump and SWG and see if they are off. Look inside the timer box by the equipment and see if it is running and how the trips are set.
It is difficult to tell what is going on with the valves you have and the way they are set. The pump and heater have drain plugs. You should locate them and see if they have been removed for the winter.
