Service light on but no error codes
csuebele
15
Cornelius, NC
Pentair Intellichlor IC-40
My mastertemp 400 has the service heater light is on, but there are no error codes in the panel nor on the back of the board. I disconnected the flow switch and no lights came on. Any idea what the issue might be? Attached are 2 photos showing the service led but no error code leds
Is Service Heater still on?
Turn off power and then restore power and show the bootup process and check for errors if the Service Heater Light comes back on.
The following are the LEDs:
  1. .....PS (Pressure Switch)
  2. .....HLS (High Limit Switch)
  3. .....SFS (Stack Flue Sensor)
  4. .....AFS (Air Flow Switch)
  5. .....AGS (Automatic Gas Shutoff).
  6. .....Service System
  7. .....Thermistor
  8. .....Heating
  9. .....Pool On
  10. ...Spa On
  11. ...Service Heater.
Show the whole board.
How about LED7?
I took the covers off and checked the igniter. Seemed OK. At first, I turned it on and just the fan came on - it didn't do that before. Turned it off and and again, and now it's heating - for the moment. It might not work, if I turn it on and off, but I wanted the spa to get to temp and see what happens, and to let my wife use it to help with some physical therapy that she's doing.
Reactions: JamesW
The people who answer questions are volunteers.
If you find the site to be a good resource, please consider making a donation to help support the site.
Thanks.
