Could the spider gasket be bad ,allowing gunk to pass through without going to filter ?
Just a quick note: That last picture is showing a bit of blue. I swear it is!
Looking good but just remember that since CYA is now at 30 that target SLAM/shock level is 12 and Mustard algae is 18.2. Yes in the sun it will come down fast but want to be careful how much time it stays near 18 and you do not want to go above 18. Just as long as you are mindful of these but looking good overall.
Here is the mustard algae chart so you can appreciate the buffering effect CYA has on the chlorine.
The one on post 274.
Good morning, Richard.
I know this process must be feeling painfully slow, but am happy to see a bit of clearing/depth which should mean your filter is starting to catch up.
Since you're still losing quite a bit of FC overnight, the SLAM is still the focus to stay ahead of algae reproduction. That is essential in order to help the filter catch up. Based on the rate of clearing, it sounds like you're getting about 6" of clarity a day. So maybe in a few days you'll be able to see in the shallow end/slope just how much silt might be on at least the shallow end floor and we can work up a plan for that.
I'm only avail for quick check ins this week but for the future, I'd like to know a bit more about your well water to help support you in final phases of this recovery.
If you have a chance, can you look up your records from when you bought the house? The well evaluation should include test results or comments addressing your iron levels if they're high.
This does not affect the slam per se, because you cannot treat for metals while slamming - first you have to pass the slam criteria. But it might play into post-slam cleanup.
Sending you more POP mojoKeep at it and cheers to clear!
