How did you make your own?
So Richard, how does it look? If it's real calm, can you see every little crease and fold?
I was going to try to catch up on this thread, but I think I'll just wait for the movie adaptation. Epic!
Excellent news.<br>
For the wrinkles, just so you know, if you have scuba gear or are good at diving you might be aple to smooth them out using two plungers...but you'd need a weight belt if its deep end. I know a PB who does this in my city for $95 an hour. He'll also use a vac without the head on it.<br>
When everything is normal post slam we can see if Metal Magic, the easiest to use, lifts the stains.<br>
If not, there's another, more complicated proceedure that should make a dent in them, but I'd rather see you SWIMMING...which btw, you can do now that you can see clearly, even at slam level.
PB can also refer to Pool Boy/Girl/Person who helps with cleaning, equipment, opening/closing of your pool.
Weightbelt would be worn on your person IF you were using SCUBA diving gear with underwater breathing. It would keep you sunk at the bottom liner to work on it without fighting to stay down. Do not use a weightbelt unless you are a SCUBA diver - danger to your own health (drowning risk) and liner when you would drop it to surface. Safety first, never dive alone/have an adult watching you.
If the liner is in good condition and wasn't abused by chemicals sitting on it, then you may be able to push the ripple to the edge with a plunger or two, or by rolling it out to the edge. Some people only succeeded after draining all but a foot of water over the wrinkles. The risk of attempting a wrinkle move is damaging the liner if it isn't in good shape and relatively new.
