Assuming you're using the same pump then make sure the installer checks the impeller for debris. Seems like your pressure dropped from 'normal'.
+1 - Yak covered any SW suggestionsMind meld!
If he's coming we'd, ask him to bring the external vac anyway. I think with still water you'll be able to see well enough by then actually...and I think sand in this case is a good choice given the well situation and the fact that the pool guy s both accessible for support and was headed the right direction on his initial advice![]()
I would rather vacuum myself to keep costs down. (...)I manually leaf skimmed the pool so there are no floating organics.
I have lithium hypochlorite sitting on my shelf. It is old, but the box has never been opened. What do you think about me using it up?
Make sure the installer uses unions on all the pipes connected to the valve. Otherwise you would have to cut them if it comes time to work in the filter.
No problem. It was just another option to potentially speed it up, but as you point out, you being able to do a proper vac after he leaves is great too. Great job on the skimming.
As long as their are no other active ingredients, way better and safer in your pool than sitting on your shelf.
And technically, while it (thankfully) doesn't have CYA or CH, it isn't pure sanitizer as Joyful explains:Lithium, as a metal, is inert in pools and won't stain like iron or deposit like calcium.
But for the odd packet to use up, no worries. It should dissolve easily as well, but you may want to add in the shallowest place so you can brush the bottom right under where you pour, or wait for pump to be up. A search of the forum didn't find anyone mentioning anything for or against pre-dissolving in a bucket with water, so perhaps that would be good if you want to do it before pump is up.Lithium hypo is expensive and it adds a few other chemicals to the pool water that are not great (chlorates and sulfates).
On the bright side, according to one of our TFP expert's:
Sounds great! It will be good to use them up! Any other questions about what you're going to be doing after you're back up and running?
Actually, Richard, in seriously swampy waters that have had years to break down organics like leaves, your experience is not uncommon...yes, it settles out in essence. And in those conditions its impossible to get it vacuuming blind.
The reason I'd suggested asking the pool guy to bring his external vac was so that YOU could do the slow vac and yet keep it out of the filtration system to avoid clogs -- while he was installing the filterI didn't thnk he'd necessarily charge you more if you were doing the vacuuming. the only snag with that idea is you'd need to overfill the pool a bit so that there was enough water to test the filter despite vacuuming.
If you can see where the drifts begin and end so that you can slowly work inward (eg keeping a bit of clean liner under the vac with the edges of the drift to minimize clogging) then there is no reason not to vac tomorrow if the guy has the vac on his truck.
When you vac with YOUR system, clots or stones or bark/twigs if there are any in the sediment might clog your pump basket or get hung up in your impeller, meaning you'll have to stop, clean it out, restart and then get the suction again. Its a bit of a pain in the butt. That was the only advantage to the external vac idea.
Either way, get the debris out now that you can see where it is, then once the risk of clogging is gone, open up that main drain and get full filtration going to finish up the slam![]()
Did filter get installed? Is it a nice one? Of course we will want pics![]()
