More areas of the deep end are slowly coming into view. I can now see addtional deposits of silt adjacent to the other area I mentioned earlier. I can also see a small pocket of debris at an opposite corner area a foot inward. It seems like the direct sunlight overlooking my shoulder helps "illuminate" the deep end. The only areas not observable at this time are the deepest areas of the pool. Mind you what is visualized is not 100 % clarity, but enough to see or make out that debris is settled in any given area. If progress can continue along these lines than visualization should be had within a reasonable time.
I am adding diluted DE on a bit more aggressive order.
Onward !
Onward !
