Scale Removal from Glass Pool Tiles
Drewmich
Active member
May 20, 2018
38
PORTAGE-MICHIGAN
I finally decided to try blasting the water line scale off my glass pool tiles - using glass beads.
It worked perfectly at the lowest air pressure possible ... but I have a small issue.
When the tiles are wet - they look like new ... when they are dry - they have a fine haze on them.
Is there a method or product I can use to "polish" them to restore the clean clear look when dry?
I have my pool drained and getting ready to refill next week so now is the perfect time to try something.
Let me know if any ideas.
DJFaninTN
184
Panama City Beach, FL
ever thought about using a DA polisher like they use on a car? it's designed so it won't burn the clear coat. different colored pads are used for cutting or polishing.
you might could find someone local who details cars and they would have all the tools and polishes already.
Drewmich
Active member
May 20, 2018
38
PORTAGE-MICHIGAN
Good idea ... when done ... I'm going to apply a special sealer product.
Using - Oceancare Products Pool Tile Restorer - Quart Trigger Spray
I'll let you know how it works out.
Drewmich
Active member
May 20, 2018
38
PORTAGE-MICHIGAN
The Oceancare Products Pool Tile Restorer - Quart Trigger Spray product was ok.
It restored about 80% of the original glass 'color" but has worn off during the summer.
I have gotten used to the loss of clean glass shine from the original look ... but will reapply the tile restorer in the spring.
it is very easy to do.
