New pool. Salt Level is reading 3900. Google tells me that the correct salt level is between 2700-3400. My salt level is at 3900. Is this too high? Can this cause damage? Thanks for help
Welcome to the forum!
The Intellichlor will flash the Salt green light if the salinity is high. Is it flashing?
Up to 4500 ppm salt it would be time to be concerned. For now, no issues.
I suggest you read ABC's of Pool Water Chemistry.
No sorry that was a separate thought on the Cyanuric Acid. Lights on IC40 are green no flashing so I guess I am good there.
As I was looking at the levels on the app I noticed that the cyanuric acid was at 0. My pool builder has been controlling everything until now but he is on vacation. Just wondering what the cyanuric acid level should be at?
You need a proper test kit, see Test Kits Compared. I suggest the TF100. A proper test kit is needed to get the accurate water chemistry results needed to follow the TFP protocols. With a SWCG, you also should have the K1766 salt test kit. The Speedstir is very helpful in getting good test results.
