I have a question for everyone to see if this has happened to someone else. A couple of weeks ago to temp in our hot tub started to rise above the temp that we set; which was 99°F. I have noticed that pump #1, which is supposed to switch for 5min every hour to circulate the water, seems to be on a lot longer than that. The temp has been escalating up to 102-104°F. I have also noticed that pump #1 also seems to running with less force when switched on than it has historically at its max speed. I'm not sure if there is a way to reset the system or am I looking at replacing this pump. The pump is on its standard or"st" setting. The only way to get the temp down is to open the cover and turn it off at the gfci breaker. Just looking for some advice before calling for a technician. Thanx for help in advance
