I have just purchased a house with a beautifully replastered 30k in-ground pool in New England. The equipment is VERY old, the piping is patched to heck, and the pad is digusting. Also, the existing DE filter has started spewing de into the pool, and having replaced the manifold and grids, I gave up on it--too much hassle just opening it up. The multiport feels like it's about to give way and the pump is a single speed.
Overall, time time just start over.
There are 2" stubs out of the ground for the skimmers/returns, and a couple of 1 1/2 inch stubs for ?? I'm guessing old main drain and possibly a suction port that both appear to be plugged in the pool. (I got literally zero info from previous owners).
I have purchased
Pentair EC-342001 SuperFlo VS
Pentair EC-188594 Quad D.E.
FV-C Control FlowVis
those are on the way for next week.
I have some jandy valves and pvc fittings, and would love some feedback on my planned pumbing of the new stuff. Based on some feedback on this an other sites, I elected to not use a multiport, as I'm the kind of guy that doesn't mind opening up the tank when things need to get cleaned, and I'm going to plumb in a way to skip the filter if that is needed, using the three way valves:
My questions:
1. In the current plumbing, what the heck is that flex pipe that goes from after the pump to after the filter? Is that some kind of balance or... I dunno. I'm assuming it helps in priming or preventing airlocks or something, but I'm unclear on if I need it in my new design...
2. With the new design, for winterizing, I have shut offs before two full-size 2" plugs, then down into the ground--I think that provides what is needed on that end, but unclear to me if I need some kind of blow outs on the equipment side. Can I just open the drain on the filter and pump and gtg? Or should I cut in some inline blowouts or stub onto something somewhere. I am COMPLETELY NEW to pools, and have never opened or closed a pool.
3. For cleanout/troubleshooting I normally put cleanouts at as many turns as I can eg
But unclear on if that is something that is done in pool plumbing? Particularly for the vertical pipe stubs to/from the pool, is it worth putting the cleanout/blowouts "in line" with the actual pipe?
3. There are unions built in to the pump and filter. Should I add them around the flowvis? anywhere else? They are expensive, but I'm happy to add them wherever needed now vs struggle later...
4. The flowvis is also a checkvalve. It's unclear to me WHY it is a checkvalve or where I or even if I need a checkvalve. I don't have one in my current system, so I'm just wondering if having one is going to cause issues priming or winterizing or whatever, and if it's worth having this thing if it will cause headaches. I got it because some guy on youtube says he always puts them in, which, yeah, maybe not the best way to decide something. tldr: should I have a check valve. If so, is this the best spot. If not, is there a flowmeter recommended that is not also a checkvalve.
5. I plan on installing a swg later. Leaving space for it between filter and return line shut off. I feel I might as well add the T and jandy 3 way now (I ordered the valve, it's on the way but that's why I don't have a picture with it and you see this ham-handed text--hopefully you get the picture). Just wanted to confirm that my instinct to put the 3 way on the "main" line is correct. If you can picture it, I -could- put the T and the jandy reversed, but something about that arrangement I don't like. I like having the valves in line on the main line from filter.
EDIT, duuhh. Forgot the picture
6. Any advice on supports for the piping. I have used clevis hangers bolted into the ground to hold up pvc piping before, so I'm tempted to do the same here, but I'm not sure if there is a more typical way of supporting the pipes...
I'm sure I'll think of other questions, but mostly hoping to get some feedback on this and any suggestions on stuff that's worth adding now or re-routing.
Thank you!!
I have purchased
My questions:
Thank you!!
