Hi,
I'm receiving a hi limit 1 error after the water temperature hits about 95 degrees F. The unit door gets pretty warm to the touch. I recently replaced the unitherm governer but not the bypass. I believe the hi limit is working properly considering the unit itself is becoming warm (greater than 135 degrees F). The water flow is strong and I do not hear any rattling. Is the next culprit most likely the bypass spring? The unit will also properly refire once it has cooled down enough.
Thoughts?
Thoughts?
