Hi, so dumb question, a raised spa , it will drain down when spa main and return is open and pump is off. There is one check valve on the return (which i replaced internal flapper on couple years ago).
It will still drain down if i don't turn off the main...turn off the main problem solved. Shouldn't the main have a check valve put on it too? it's not buried i checked and the return valve is obvious at ground level. Seems wierd
they didn't put one on. I assume i should do this but just looking for confirmation as seems wierd it wasn't added to that line as well. thanks!
