We are replacing our pool automation system and are thinking to using a simple timer for the pump this time. Does anyone know if there is a timer (panel mounted, outdoors) that can be used for turning the pump OFF at a certain time without using any ON settings at all? We always turn the pump ON manually and don't want the pump to turn on automatically with the timer. The timers we have looked at so far all seem to require a pair of ON/OFF settings which is not what we are looking for. The trick of using an ON time a few minutes before the OFF time is also not desirable. We always want to check the pool before turning the pool on the morning so we don't like the idea of the pool turning on automatically. At night it would be good to have an automatic OFF (with a timer) at a set time to make sure we don't forget to turn it off. Some days we don't turn the pool on at all so having an automatic ON shortly before the OFF is also not a good fit for us. Any ideas what we should look for? Thanks!
