Pump sitting on concrete blocks
miamicuse
126
Fort Lauderdale, Florida
I have recently raised my pump to sit on three 4" concrete blocks.
It is not very steady. It doesn't move while it's operating, but if I need to open the lid, I struggle with opening it without rotating either the concrete block or the pump even if I am steadying the motor with one hand.
Which leads to the question, do I have the pump positioned correctly over the blocks?
There are two "feet" (labeled B) in the middle of the housing, which I guess is a "hold down" but my blocks are not as wide. There is also a plastic "tail" (labeled A), should I move the blocks closer to the motor which is heavier? Like center the blocks between the mid point between A and B?
103702
Sorry if this is an exceedingly stupid question. :unsure:
In all honesty, I would redo the plumbing so the pump sits on a single concrete paver pad on the ground. IMO that’s a disaster waiting to happen, as the vibration will cause you problems with the plumbing.
At the very minimum, you need bigger blocks under the pump to support it better.
