Hi all,
This is my first full season with my new inground FG pool. Finished a SLAM a few days ago and the water is beautiful. Chemistry is perfect, just waiting on warmer weather to start the heat pump for the season.
I have some questions :
1) Pump run time and speed - I have a Hayward Variable Speed pump. I do not have a lot of head on my plumbing so can run the pump at very low speed and get good circulation. I am under the impression that running the pump at a low speed 24/7 is the most efficient in terms of energy consumption. This is what I have been doing. Is this the best solution versus running at higher speed but intermittently? I am guessing that a higher speed will have stronger circulation and will force more dirt through the filter that perhaps would not get sucked in at a lower speed? What is recommended? I do not have a main drain, only 2 return jets in the shallow end and the skimmer in the deep end. Pool is only 26x12.5
2) SWG settings - obviously linked to point 1 above, SWG only runs with flow so if running 24/7, it appears like I need to have a VERY low SWG setting. Thinking around 10% maybe?. I have a T-15 cell with an 8800 gallon pool (I believe T-15 can provide chlorine for up to 40k gals at regular salt levels and 25k gals at low salt levels, so it is over sized). Pool Math tells me that at 100% power, the SWG T-15 cell could generate 19ppm FC per 24 hours in my pool. I assume this is not the low-salt version that I have so let's assume a bit less.
Before I spend too much time on trial and error, thought I would ask the forum!
Thanks in advance
Thanks in advance
