But if money is no object...
If you ever foresee wanting to add an automation controller to your setup (a fancy timer that can be run from inside the house, from computers, from smart phones, etc) and possibly a salt water generator, you want the controller, the VS pump and the saltwater generator to all be compatible, and of the same brand, in order to get the full benefit of remote control.
A hodge-podge of brands and models can be made to somewhat obey an automation controller, but just in a rudimentary "on-off" way. To get feedback about the pump and the SWG, and to be able to fully program both from your vacation home in the Philippines, you need the same-brand compatibility.
And while you might not see the need for automation now, think ahead to when you're less mobile, and/or your lifestyle changes and you find yourself away from home a lot. The ability to check in on your pool might come in handy.
And you don't have to buy anything now for automation, I'm just saying if you someday might, then you want to buy a compatible pump now. Then maybe the compatible SWG next year, and the controller some other future day. Some pumps can work stand-alone with your smart phone, without any other controller, and then later integrate with your automation controller. So you could have some remote goodness with just the right pump, and build your automation system as budget allows.
I didn't study up or plan ahead for what my "someday system" was going to be, and ended up buying some equipment, early on, that didn't later fit the eventual plan. It's the single biggest pool-related purchase mistake I made, and still regret.
