Just wondering, do I need to add water into the pool pump filter basket every time I open up the lid to empty it out? or can I just close the lid and turn on the pump and it will prime itself?
Depends. When you remove the clear lid to clean the pump pot, if most of the water remains in the pot you are fine. But if the water level drops significantly for some reason, you should top it off before closing it with the lid and starting the pump.do I need to add water into the pool pump filter basket every time I open up the lid to empty it out? or can I just close the lid and turn on the pump and it will prime itself?
If you have a check valve before the pump, then filling up pump pot is less important.Just wondering, do I need to add water into the pool pump filter basket every time I open up the lid to empty it out? or can I just close the lid and turn on the pump and it will prime itself?
The flow at the return yet is very low, I used to be able to push my finger into the jet and feel the pressure push back. Now, I put my finger in and I can now stop the flow with my finger in the return jet.Can you confirm for us ..... how is the water flow at your return jets? Is it strong? Is it possible the water in the pump basket is full and so clear that it just "appears" to not be moving when it actually is?
I have a DE pool filter, I cleaned it about 2 weeks ago.What type filter do you have?
When was the last time it was cleaned?
With pump off, have you checked the pump impeller for obstructions/debris?
I did a full teardown. Its a Hayward DE filter (don't have the exact model number), and I added 6 lbs of DE using the 1lb Aladdin scoop.Did you backwash and recharge your DE filter or do a full teardown?
What exact filter?
How much DE did you add and how did you add it?
DE filters are quite susceptible to algae-induced clogging. Is your filter pressure high?I did a full teardown. Its a Hayward DE filter (don't have the exact model number), and I added 6 lbs of DE using the 1lb Aladdin scoop.
Before the filter was cleaned, it was cloudy. I cleaned the filter, fully opened up the filter, washed off all the DE and then recharged with new DE. The cloudy water cleared up after about 2 days. After the 1st week, I noticed it started to get cloudy again, so I went ahead and shocked it, but as of now its just been getting more cloudy. Last night I went to add some muriatic acid and turned on the pump to 3110RPM and thats when I noticed that the water wasn't running through my skimmer or it was running very slow.
My filter pressure is high after about 1 week after cleaning. When it was cleaned it was reading at 15psi, now its at 25psi. I am using the TF-100 Pro test kit.DE filters are quite susceptible to algae-induced clogging. Is your filter pressure high?
It sounds like you have algae (evidenced by the cloudy water), and the dead algae could be clogging your filter. A dirty DE filter would cause the pump issues, and low return flow, that you describe.
You don't note what test kit you use, but do mention "shock." TFP methods rely on self-testing with a recommended kit, and the SLAM process for clearing up a pool.
SLAM - Shock Level and Maintain
We’ve all had to deal with a green pool. Clear algae from your pool with a SLAM! Read here to use shock level and maintain to clear your pool.www.troublefreepool.com
Swimming Pool Test Kits Compared
What pool test kit should I buy? Why shouldn't I use test strips? Our recommended test kits will pay for themselves in no time!www.troublefreepool.com
IMO, backwash again, then check your PSI as often as you can, a 15% to 20% rise in a couple of days, backwash again, If its rises quicker that, ( do to a heavy algae removal), open filter and perform a cleanout. You should be doing a complete out at the end of the SLAM process in any event.It sounds like you have algae (evidenced by the cloudy water), and the dead algae could be clogging your filter. A dirty DE filter would cause the pump issues, and low return flow, that you describe.
Will give the backwash a try later today. Any idea how much DE I need to put back in?IMO, backwash again, then check your PSI as often as you can, a 15% to 20% rise in a couple of days, backwash again, If its rises quicker that, ( do to a heavy algae removal), open filter and perform a cleanout. You should be doing a complete out at the end of the SLAM process in any event.
I am definitely going to perform this test right after I resolve the issue with my pool pump. I am having trouble maintaining chlorine levels though. I'll have to retest and put up my results.Sounds like the quality of the water may be in question (cloudy). There are no test results listed in your Poolmath logs, so it would help at this point to see a full set of water test results. But at the very least, consider doing an Overnight Chlorine Loss Test.
