I need advise as to how to proceed. I am thinking to replace my current pump with a variable speed pump (I have a quiet heat pump and do want to have the energy savings of a VS) -- but I live in Florida so lightning is a concern.. I have read on this forum it is possible to install a surge suppressor.
I am just concerned whatever I replace with will fail in the same way, not sure I want to replace a very expensive pump.
OK This is a bit long, but I feel without details it will be harder to help.
When we bought the house there was a very old Single Speed rusty pump, it was on its last legs-yet ran for 2 more years. It was replaced with the current StaRite 1.5HP (2014) pump. After about a year StaRite failed and the backend (the motor?) replaced twice (within about 90 days) then maybe 1year later the bearings were replaced.
This always ended the same way... Pump is quiet in the beginning gets louder... then REALLY loud.
During priming the water in the pump skimmer empties first then fills - I have two (pool) skimmers that have shut off valves and a main that has no shut off. I am thinking this is a main reason the pump eventually wears out.. lack of water causes priming to take too long..
Things got worse I think with a plug in vac (no boost pump).. I would have to tweak the skimmer valves to get the vac to suck enough.. but that introduced bubbles to the pump skimmer.. multiple places said it's fine.. but something told me it isn't.. I think this is 2nd reason for pump failing.
3rd thing water level would drop and the pump would endlessly try to prime.. I haven't made that mistake in a long time, but it happens.. Florida sun evaporates oh so fast.. and a possible leak somewhere.
4th.. today the pump became really loud.. I checked the filter and many dead swarming ants were stuck to it. Otherwise the filter was clean (almost end of SLAM)
Final note: ~2 weeks ago I did remove that vac and bought a Robot (I love it, but that is another thread)
During all of this my SWG failed (yet another thread) so I started using chlorine tablets (I know I know) and.. well I had to SLAM.. but now.. my pump is so loud I can't run it 24hours a day.
What would you all recommend me do? I am IT techie but this pool equipment somehow leaves me without a clue. I think I need a pool company to help, not sure which.
I have attached some pictures. I have a small video but the forum doesn't seem to like uploading it. Maybe the wrong file format?
Thank you!
-edited re-upload larger size photos & changed "pump" to "motor"
Thank you!
