Hello Everyone,
We have recently completed our new pool build and when we installed our Pentair Intelliflo VSF I was excited to see the ScreenLogic app displayed the wattage, RPM and flowrate. My excitement quickly dwindled as I noticed my pump was running at 3000 RPM pushing a whopping 54 GPM. It seems I’m having to run a higher than expected RPM to achieve the desired flow.
I read Hydralics 101 prior to our build and when I contracted with my PB, I specifically asked about Hydralics, head loss, etc and he assured me we would have an extremely efficient system. Our PB builder used 2” lines for the returns and most of the length for the floor drain were 2.5”, with two skimmers independently plumbed using 2”.
My pool setup consists of the following:
Pentair VSF pump
Pentair Quad DE 60 filter w/ multi-port valve
Pentair Ultratemp 120 HC heatpump
4 returns w/ 3/4” eyeballs
2 skimmers, plumbed independently
1 Line for suction cleaner (plumbed as 5th return in an attempt to reduce TDH).
1 main drain (dual drains in T)
17,000 gallon rectangular pool
3.5’ – 6’ deep
The equipment pad is 10’ from the pool and 8” below the surface of the water. The base of the pressure gauge on the filter is 28” from the surface of the water.
The heater is plumbed into a 3-way valve and the chart below was taken w/ the valve sending ½ the water to the heater and ½ the water through the bypass:
On paper, everything appears to be picture perfect but nothing is adding up and I’m at a loss. This is our first pool and unfortunately plumbing and I don’t always get along. I was trying to build the most efficient pool but according to the folks at Pentair I’m running a high total dynamic head and my pump isn’t running as efficient as it should. I’m at a loss at what to do. There isn’t a significant amount of elbows (or at least I don’t think there is). I’ve read every thread on TFP I could get my hands on and I’m still confused what to do or where to start, hence the reason for my post. Any advice or direction would be greatly appreciated.
Thanks in advance,
Brandon
Link to GoogleDrive for pics of plumbing:
https://drive.google.com/drive/folders/1z0kdz7g0S7ZZZMu3efw743_rlFSgcd3M
Pentair VSF pump
3.5’ – 6’ deep
RPM | PSI | GPM |
1000 | 0 | Below 15 GPM |
1250 | 1 | 21 |
1500 | 3 | 28 |
1750 | 5 | 35 |
2000 | 7 | 42 |
2250 | 10 | 47 |
2500 | 12 | 52 |
2750 | 14 | 56 |
3000 | 18 | 61 |
3250 | 20 | 66 |
3450 | 23 | 69 |
Thanks in advance,
Brandon
