Pump below water level, how to not have water gush out so I can clean basket
Aug 30, 2019
21
South Salem, NY
Hey all,
Brand new to pool ownership. After a couple weeks of having a pool guy maintain the pool weekly, i started to do it on my own.
I vacuumed the pool last night, and afterwards i now hear a "graveling" type of sound coming from around the pump (I could have gotten air in it?). I saw some debris in the pump basket, so turned it off and went to open valve. Water was pumping out very fast so had to close it quickly. I have been reading online and havent really found an answer, they say to close valves but i dont have that many, just one valve really that i see.
how would i go about closing any skimmer/etc lines so i can clean the basket out?
Here is my setup Thanks!
ajw22
11,667
Northern NJ
Welcome to TFP.
Give us a wider view of your pump and plumbing around it and the rest of your equipment pad.
What type of pool is this? In ground? Above ground? Plaster? Please put details of your pool in your signature. It helps us help you better.
Bama Rambler
23,698
Turn the 3-way valve handle away from the pump suction and set the multiport valve to Closed. That should stop the water from gushing out the pump basket when you open it.
Reactions: PointeTaken
