Hey friends. I'm having an issue with my pump basket not filling all the way when priming/running.
We called a pool service company out to look at it and they replaced some O-rings on the set up and proclaimed it was fixed, but the next day the pump basket was again super low. We've had this pool for 3 years and never had a problem with the water in the pump basket being so low - it's usually right up to the top or nearly so.
Other than replacing the O-rings, we've cleaned the filter and skimmer, checked other connections for air leaks, and cleaned out the impeller.
Is there anything else we can do for this? I've heard that having low water in the pump basket is bad and could damage your pool, but the repair guy told me "it's just how your pool runs", shrugged his shoulders and didn't do anything else to help me.
Is this true? If not, how do I go about fixing this? I attached a picture but not sure if you can see the water level, so I drew a yellow line where the water is sitting in the basket. If I need another service guy to come out, can i get recommendations for someone in South Houston, TX?
TIA.
TIA.
