For the past few months, I've had occasional problems retaining prime. I have replaced seals, check valve, pump basket cover, etc. and then realized I had a small leak in one of the skimmer paths. I turned off suction to that pipe - still have another skimmer and main drain - and priming worked well for some time.
It will lose prime once every week or so at this point - and not regain it. Because of its infrequency, I am not sure there is a systemic issue, but I certainly want water circulation.
Can a small leak on the booster pump suction impact prime of the main pump?
The pump housing is around 8 years old and the motor is around 5 years old.
With the above scenario, what would you do?
