What you entered is fine to start. First pic says, run the pump 24/7, and set the output to 35% and it will generate 5FC over the day.
5 is a good target to start in Houston in the summer.
When you are ready to start it up, raise your FC to target range for your CYA using this...Link-->
FC/CYA Levels
Then turn the cell on. Test in 24 hours. If you are in range still, then your setting is good. If you are below range, raise with liquid again to range and turn your cell up %. If you are above range, turn your cell down a bit.
^^^Make sense?
