PoolMath bug iOS + feature request
acKsw
14
Sydney, Australia
Both of these entries were added at the same time but one of them was catching up for the day before.. so “2 days ago” is Jan 28, when I put the log in, not the actual date of the chemical add (Jan27 per RHS) - it’s a bit confusing.
Also would be great to have the ability for PoolMath to:
1) have an option for liquid chlorine (I know it’s the same chemical), and
2) remember if I have changed the concentration of the chemical and use that value when adding again (eg liquid chlorine is 13%. Every time I go to add bleach it defaults back to 6%.. but if I do add bleach the local stuff here would only be around 4%. It’s a lot of repetitive re-entry to keep correcting something that I can’t change).
ajw22
27,967
Northern NJ
Pentair Intellichlor IC-60
@Leebo should be around soon.
Leebo
Admin
10,842
Eastern Ohio
Try this as you’re slightly adding chlorine opposite of the expected behavior.......even though it’s also how I add. 😂
Go into the FC Tile and insert into the “Bleach Chlorine %” field that you’re using 14% and hit done. That field should be saved and update through the the App.
