Pool won't hold chlorine
poolgirl-30
5
Liberal, MO
We drained our 25,000 gallon pool and started with fresh water. It's been open a week and I cannot get a chlorine reading at all. Luckily it is still colder here so no trouble yet. The pool company we use said they put stabilizer in since it was fresh water. Any suggestions? Chlorine tabs are not going down. Water is flowing into and out of the chlorinator.
mknauss
22,793
Laughlin, NV
splashpad
1,994
SE Kansas!
Welcome fellow midwestern'r ;)
If you're willing to handle the testing & maintaining of your pool, TFP methods save you lots of hassle & $$ over the long & short-term of pool ownership!
Can you add your pool & equipment info to your signature please?
poolgirl-30
5
Liberal, MO
poolgirl-30
5
Liberal, MO
I did all the testing with a Taylor K-2006 kit. I’ve been told to adjust chlorine first. What are your suggestions. This happened last year & I was shocking the pool constantly to get chlorine in it & it wouldn’t last anytime.
mknauss
22,793
Laughlin, NV
Add 3 ppm FC worth of liquid chlorine now.
Get 30 ppm worth of CYA dissolving now using the sock method.
Follow the FC/CYA Chart based on 30 ppm CYA once you have it dissolving. Liquid chlorine must be added daily.
Add muriatic acid to lower your pH to 7.6. Test that every other day or so as your TA will push the pH up.
Reactions: poolgirl-30
poolgirl-30
5
Liberal, MO
What’s the formula for calculating ppm?
splashpad
1,994
SE Kansas!
If you can stop using the pucks, that would be better long term, how many are in the dispenser? ((Use PoolMath to figure out how much CYA will be added))
Do you have any local convenience stores that you can go grab plain cleaning bleach? (it will be 6% strength) (no scents, not splashless, not easy pour, etc)
Until you can make a trip to Walmart for some Liquid Chlorine 10% Pool Essentials Chlorinating Liquid - Walmart.com
Use PoolMath, enter your pool's dimensions and the details in the lower section, and you have 2 options, the Now & Goal and the "If I add" section.
:edit: I see you posted an APP screenshot, if you enter your pool details in the app, it should tell you how much to dose, I prefer the PoolPal app myself (but no iOS) :)
