I've researched but can't find the answer to this:
I have a 10k gal pool with a connected spa (negative edge spillover). Single variable speed pump, so either the pool is running or the spa.
I've been balancing the pool water and shocking as needed as well. Sometimes when I first turn on the spa, I get a strong chlorine smell, which leads me to believe the free chlorine could be low (high chloramines), perhaps due to water sitting in the pipes that doesn't receive shock treatment when pool pump is running.
So, do I also need to run the spa and add shock? Was a bit concerned it may not be safe for the finish etc.
