My pool pump died right before I added the polyquat 60. I just need to add that and blow out the lines to close the pool.
The water is clear and was at SLAM levels.
I would rather not buy a pump right now, the last one I bought in 2017 was $350 the same one now is $700.
The front seal cracked and leaked water into the motor housing which fried the windings.
I am close to needing a new DE Filter as well, so I would like to take the time to pick the right setup and complete that and any associated plumbing changes next year.
Any thoughts on the best way to get the algicide circulated through the pool?
The only real idea I had was dropping a sump pump into the pool and letting that circulate the water for X amount of days.
The other thing that slightly worries me, is that even though the water is balanced now, will it just go green over the next few days and then I'll be closing a green pool. (Though I am sure that is what happens underneath the cover anyway so maybe it's not a big deal.)
20x40 in-ground pool.
Link to the pump I had before:
