One add to the information here is that after getting on the phone with Pentair a half dozen times over a couple week period, they were able to schedule a local pool company technician to come out and update my IntelliFlo 011056 firmware from that 3.04 version, it fixed 2-3 weird bugs that seemed to be issues with the app itself but were fixed via the pump update.
They replaced the entire pump drive with a new unit. The odd thing is that if memory serves...it's a brand new pump drive direct from Pentair, however it is now on version 2.017 or 2.17 I believe which would seem like it went backwards. But hey, it works!
We were also able to get the firmware/software updated on the IntelliConnect and IntelliChem. The Intelliconnect shows 39 DBM on airport utility app so the connection is excellent and it has not dropped one time since we plugged it in. The initial connection was a nightmare but once it was online and updated, it really seems to be a great system.
I should be HOPEFULLY done with a SLAM here soon and then I can see how that IntelliChem works. It flows very well and with the new plumbing setup, I am able to run my pump at 1800 rpm using 375 watts and run the heater showing under 4 psi on the DE Filter gauge. Legend Kreepy Krauly wheel spins at 30-31 rpm with primary pump at 1750 rpm at booster running using about 330 watts.
So it's all very efficient, has a heater bypass via the app and full control of SWCG with freeze protection, temp display, heater control etc.
