- Jun 1, 2018
- 16,167
- Vinyl
- Hayward Aqua Rite (T-15)
You need a center mounted gauge like This instead of the bottom mounted type you currently have anyway.
Will that type fit into the hole that my gauge is in now??You need a center mounted gauge like This instead of the bottom mounted type you currently have anyway.
I put 70 oz in from the pool bleach from walmart from last year. I have to use them up. They were stored in the box in my garage. So i used a little more than 1/2 gallon. Will test tomorrow and move forward from the results then60% of a gallon of fresh chlorine. Or the whole gallon of leftovers.
That's just to get you until tomorrow when we can get a valid CYA test.
Yes.
YesWill that type fit into the hole that my gauge is in now??
You could have put the whole gallon if you wanted. It’s probably degraded a bit.I put 70 oz in from the pool bleach from walmart from last year. I have to use them up. They were stored in the box in my garage. So i used a little more than 1/2 gallon. Will test tomorrow and move forward from the results then
Do u really think i need to slam. I was hoping to not go thru all thst work. I am exhausted. Hopefully my test results will be such that some chlorine and whatever else will do the trick.Also have some evening reading.
SLAM Process
You can get some solid effot in tomorrow and Monday and be well on your way.
I have like 7 gallons left over from last year. How bad can they beYou could have put the whole gallon if you wanted. It’s probably degraded a bit.
They're probably half strength. Test for your baseline, pour a whole gallon in and test 15 mins later.I have like 7 gallons left over from last year. How bad can they be
They don’t go bad - just may not be as strong as listed on the bottle. Use one & see where it gets you on the fc test compared to whatI have like 7 gallons left over from last year. How bad can they be
Can u tell me how to to this again. Based on a 40 CYA how much chlorine i should add snd how much muriatic acid. Even though my Ph is only8?It's great you more or less held FC overnight.
Use muriatic acid to lower the PH per pool math.
I'd add 10 ppm CYA. 30 wasn't cutting it for me a couple weeks ago. The UV has been unusually high by us.
Then dose FC daily per the 40 CYA. Start high because you're not sure what it is yet.
There is a glitch with android where the keyboard blocks the chemical addition info area towards the bottom. Press 'done' to minimize the keyboard and see the area underneath it.Thats it guys. Not sure i did pool math correct. Need a brush up course. Can u tell me where to find that and how much it will tell me to add based on my FC and CYA and Ph and TA
That's OK. It takes a minute to get your pool sea legs back.Like i said my brain went blank from last year. Really fo need a refresher course to understand what to do and why and quickly before i mess things up![]()
