- May 3, 2014
- 62,717
- Fiberglass
- Pentair Intellichlor IC-40
If you have that quick of FC drop with a CYA of 60 or higher, you have a lot of organics in that water.
SLAM level FC is not high chlorine. And no, chlorine has no effect on it.Do I need to worry that the high chlorine will etch the fiberglass?
What are their recommendations?Imagine pools says I have to hold there recommendations for the warranty, and those number don’t align with TFP very well.
The pH, TA and CH requirements from your pool manufacturer, while not in line with TFP are just fine. Keep those levels.FC 1-2
Ph 7.3-7.4
TA 80-120 with 100 recommendation
CH 80-120
Cya 30-50
I don’t see how I’m going to be able to do this, I need to get my cya to 30
But I was trying to figure that out will pool math last night. Any way I look at it my csi is going to be -.4 or less. This is going to add NO protection to my heater.
I was doing great the first couple of months before the tabs got the cya up to 80
