I would like to see the up & down arrows in the keyboard that jump to the previous & next input field, like TAB on a PC keyboard. See the 2 keys in the upper right of this iOS keyboard below the word Preview.One thing I did find that's a bit annoying, when inputting readings, click the checkbox and it goes to the next input field but doesn't scroll up far enough to get past the "keyboard" so I scroll up some more to be able to see what it is I'm typing into that field.
I'll check that one out.
I definitely can recreate this and know what you mean. Working on fixing it. The odd thing is it works correct on some devices I’m testing on but not others.
I am having that same problem on the Galaxy S10 Android phone. If I dismiss the keyboard and physically select the textboxes below the keyboard, those text boxes scroll above the keyboard. However if the keyboard is already up before reaching those text boxes, they are concealed by the keyboard.
Hope that helps.
Just pushed an update to android about the text fields being hidden under the keyboard, you should see it in the play store any time now, please let me know if it works![]()
I'm running the newest version (3.3.1 (3403) and, still have problem with keyboard popping up over the input screen. As you get to the last input before the keyboard screen you can't go any further, unable to scroll the screen up. Only option is to exit the keyboard screen, tap into the input area at the bottom of the display and then let the keyboard screen pop up again. It then scrolls that screen forward so it's above the keyboard screen.Just pushed an update to android about the text fields being hidden under the keyboard, you should see it in the play store any time now, please let me know if it works![]()
Just downloaded version 3.3.3 of the app and the keyboard problem with covering the inputs during an additional test still exists and is, in fact, worse. Where before you could scroll down to the last input, Water Temperature in my case, and click in the textbox, the keyboard would then appear and the temperature textbox would be above the keyboard. However now when I click into the temperature textbox, the keyboard appears and completely covers the input textbox.
Have not looked at the other changes yet, but am excited to see what updates have been included.
WRT the app: I just subscribed to the app and after setting everything up I noticed that I get an alert to backwash the filter even though I have set the reminder for 14 days. There is no way to get rid of the alert. On latest android.
Thank you for the welcome. I'm an official member now and just subscribed to the app.First and foremost, WELCOME TO TFP!!
I noticed that on May 4th you recharged your filter, which is likely the same as a backwash. The app was never “told” this action was done. If you go into the Maintenance tabs you’ll see the option to mark that you backwashed. Click that and the message will disappear.
