There may be good news here as the water level seems to be at or getting close to the leak. The light niche is now exposed just slightly under the trim ring. The hole under the deck has dried up considerably.
That is great news. You may be cracking the code on that pesky leak after all.There may be good news here as the water level seems to be at or getting close to the leak. The light niche is now exposed just slightly under the trim ring. The hole under the deck has dried up considerably.
Ok so the water in the hole is about dry and the drop seems to have leveled off. The light niche is like 3/4ths underwater. I don’t see any cracks in the niche housing. Is it possible the ring gasket has gone bad?
