- Jun 22, 2014
- 47,861
- Fiberglass
- CircuPool RJ-45 Plus
Honestly, I would be more comfortable with Poolguy seeing your latest update as he in in the industry and is "hands-on" all the time on this stuff. Like you, I wonder "if" the tech's attempt to fix the conduit event worked or was done properly. I do believe that to a given extent, a lot of this type of repair is doable as a DIY - not just to save a few bucks, but just like about anything else you like to know it was done right. Unless there just happens to be another tear in the liner in that area at the same height, something is compromised in/around the niche area. Let's give Poolguy a chance to get his java, shake the cobwebs, and catch-up with what we've discussed this morning and see what else might be missing.
