You may be right but I think a couple good sized drains may be in the immediate future.I still think you & home owner would be making quicker progress with adding chlorine to get to SLAM level more frequently than focusing on filter at this point
I dumped half my swamp and only had to fight the *other* 17.5k gallons. It really really helps.You may be right but I think a couple good sized drains may be in the immediate future.
With the bromide in the water that is needed based on what others said earlier in the thread. Does she know how deep the shallow end is (assuming with 42k there is a shallow and deep end)?You may be right but I think a couple good sized drains may be in the immediate future.
90% of gunk should be gone tomorrow. It would be easy if I wasn't vacuuming 'blind'. CYA is ineffective with bromide in the water.Probably need to get all the “gunk” off the bottom, raise CYA to 30, then SLAM. All that chlorine with 0 CYA and a lot of organics means a lot of wasted chlorine. I’m assuming there is still 0 CYA?
Shallow end is 3 feet. Deep end is 12.With the bromide in the water that is needed based on what others said earlier in the thread. Does she know how deep the shallow end is (assuming with 42k there is a shallow and deep end)?
Keep at it and do the best you can. The gunk is eating your FC so much less goes to fighting the water. When i got the last of mine out, I watched the pool go blue in minutes. It was cloudy and still took a while, but the green went quickly.90% of gunk should be gone tomorrow. It would be easy if I wasn't vacuuming 'blind'.
I forgot you’re fighting bromide. Continued good luck!90% of gunk should be gone tomorrow. It would be easy if I wasn't vacuuming 'blind'. CYA is ineffective with bromide in the water.
Darn was hoping shallow end was deeper that means to keep liner from shifting you can only drain 1.5-2 ft at a timeShallow end is 3 feet. Deep end is 12.
I thought the green was mostly gone until I started to vacuum to waste today. There are no bottom drains in this pool. I've been leaving the vacuum head upside down in the deep end to get some circulation down there.Keep at it and do the best you can. The gunk is eating your FC so much less goes to fighting the water. When i got the last of mine out, I watched the pool go blue in minutes. It was cloudy and still took a while, but the green went quickly.
The yard has quite a bit of slope so I can drain to a low spot & maybe drain 2.5 feet? That would be about 1/3 of the water.Darn was hoping shallow end was deeper that means to keep liner from shifting you can only drain 1.5-2 ft at a time
The pool school article recommends leaving at least 12" in shallow end to keep weight on liner and prevent it from shifting so I think your limitation is liner not the yardThe yard has quite a bit of slope so I can drain to a low spot & maybe drain 2.5 feet? That would be about 1/3 of the water.
Ugh! I did have her use a clarifier last year....Found these clumps of algae while cleaning the sand. The DE also clumped up (next pic) & is a strange color. I sprinkled some fresh DE for comparison. Are these a sign that a clarifier might have been used.
