- Jun 10, 2009
- 336
- Plaster
- Pentair Intellichlor IC-40
Hi thanks so much for that info. Yes both of my skimmers are independently ran back. The one on the left is connect to main floor drains and the other skimmer just skims and each runs back on 2.5" pipe.This may help on volume flow in pipes.
#1 FlexPVC®.com Water Flow Charts Based on Pipe Size (GPM/GPH) ie, How much water can flow through Sch 40 Pvc Pipe Size 1/2" 3/4" 1" 1.5" 2" 2.5" 3" 4" 6"
Water Flow Volume for a given pipe size based on charts, tables, formula, nomograph, & experience.
flexpvc.com
Water features do not need to go through the filter, heater, etc. as their suction is from the main pool and the flow is back to the main pool thus it is all chlorinated water. Having the 2 suction lines tie into 1 suction is normal as that is new code to prevent entrapment Also having the suction on the wall minimizes debris that is sucked into the water feature system as you only have your pump filter basket to catch it.
Having a VSP dedicated pump for your water features is good. Remember to have a valve on each return so you can independently control flow to each.
I could not tell, but are both your skimmers independently plumbed back to the equipment pad. That would be good to have if not done.
I looked at the chart you gave me and tried to decipjer it. I would imagine being in the green is optimal. I believe I read on Pe tair site that the sheer rains require 15gpm per foot with 10 being minimum. That meansmy 8 ft sheer rain would require 120gpm? Is that righy and 2.5" pipe doesn't look like it supports that in the green section? Does it help that each sheer rain is independently ran from pump and will pump work harder to move the water through 3 separate pipes?
Thank you!
