Pool deck questions
In fact the previous owner's three children left little footprints and the date (2001) on a corner of the deck when they poured the concrete.
That was a genius strategy to make you think that the new deck was original so that you would not know that the pool floated and needed a new deck.
:p
Seriously, maybe they put the pool up high due to the high water table.
In any case, I think that you need water control from a professional expert.
  • Haha
Reactions: Smalone and borjis
Have you considered putting a waterproof membrane on the slab the next time the floors get water damaged and need replacement?
That is not a substitute for the drainage you are planning. But if the water level under the slab stays high and the slab is wicking moisture then you may need to remedy it inside.
Reactions: Mdragger88
I'll tell you how that happens. The genius who built the deck poured 3-4" of concrete on one side of the house and 0.5" to 1" on the other side.
I went with the channel drain. I emailed the drainage guy to move forward with it. Fingers crossed!
I think that is a good plan, make sure the patio/deck whatever you want to call it slopes downhill that short distance from the house to the drain.
My daughter and SIL also live in Houston and are having similar problems, contractors they've had out say people all over Houston are having the same thing due too all the rain you guys are having!!
Reactions: poolnovice1
You know, I've never actually tested it. I know water going down the patio drains makes it out to the street. I'll run a hose tomorrow through that overfill drain and see if water makes it out.
The house we bought a year ago had some drainage issues too that took me a minute to figure out. Thankfully they didn't build the deck up tight to the house, and the deck is level with the existing patio slab (~ 1.5 in. down from the door sill plate). I have a complement of eight interconnected drains; one downspout drain, one overflow in the pool, three in the deck between the house and pool, and three more in the beds between the deck and the house. With a big rain the pool wouldn't drain, the water would back flow into the flower beds and ultimately run off through the yard. Thankfully the landscaping is graded away from the house so no water intrusion issues. I searched for blockages and ultimately found the culprit - the popup valve at the street was completely overgrown. Took a while to even find it.
It's a 4 inch pipe, and I'm guessing they did the popup because they weren't allowed a curb cut, or didn't want to get the approval. When I uncovered it I think I snapped the stem that retains the poppet by hitting it with the shovel. Either way it was broke when I lifted the sod off of it. So I drilled it and installed a longer socket head cap screw to take the place of the retaining stem, and gave it a pretty good amount of travel. We haven't had any substantial storm events this past year to really test it, but so far it hasn't backed up in the rains we've had. It's at least threaded so if it backs up I can remove it, temporarily or otherwise.
Good luck with your deck work, I'm sure it'll be a pretty big relief to get that all resolved.
A little late to the party with a random thought that would probably not work here but I have seen used in other areas.
You might be able to build a low thin brick planter up against the wall where it is leaking into the house. The inside of the planter would then be waterproofed. The the planter would keep the water away from reaching the house wall and seeping in. If it is coming in the door that is a problem.
I had a similar issue when we had heavy rain. I had more area between the house and the pool and had them replace about a 10' wide section of concrete and slope it away form the house then back up so now the water running out and down our drive way. My issue was the small drains couldn't handle heavy rains
I will say I agree with JameW .What you have done is good but not the cure. Seeing the picture of the basement tells me you have water below the slab and water as we all know is smarter then all of us sometimes. Like in my own home which has a 8' basement and needs water management on the exterior due to the slopes from neighboring plots. But before I do that I installed a full size sump pit with a pump. The pit about 30" deep so when the water table rises even while the interior french drain is still stark dry the fact the pit is deep the water reaches there first and keeps the water way below the french drain and no moisture whats so ever on basement slab. The only time the french drain sees water is very heavy rain from remnants of hurricanes. The water comes to the foundation walls and then drops to the footing where it gets into the french drain below the slab and follows the pipe to the pit. Put a sump pit anywhere in the slab and the water will find its way and you will probably never have to deal with it again. Just one word of caution , when you have a sump pit you must have a backup plan for power loss as its a point of water entry and it could care less if the pump works or not.
