Pool deck questions
The sump pump is not very expensive at all. Dig a hole drop the crock into the pit with some gravel, drop an inexpensive $150-200- pump with 11/2" pipe and check valve piped to the outside.
I'm thinking digging that hole inside in a ground level slab would be a bit of a problem.
I'm reasonably confident those channel drains will resolve the issue.
Houston is a bit different than many parts of the country. Typical homes are built using post-tensioned slab-on-grade construction. We have no basements, or any portion of the home sub-grade (with very few exceptions). Most homes built in the last couple decades are also built up above street level at least a foot or two, as the streets are designed to act as flood channels when the storm drains and bayous overflow. So while our water table is comparatively pretty high, adjacent to the house you'd still have to dig a bit to find water. Along the same lines, if the water table were high enough to reach the slab, ground water would be weeping out of the ground at the street.
We actually have the reverse problem. If you don't regularly water the ground around your slab, you begin to have leveling problems due to the dirt drying and shrinking. You end up with parts of your house unevenly sinking into the ground, cracks in walls, doors and windows that stick, etc. Fixing it means digging under the beam of the slab and using a hydraulic press to drive concrete cylinders into the ground until you can use them to lift the house back to level. We aren't built on bedrock around here, it's all dirt and clay.
Reactions: poolnovice1
I think that you mostly need to prevent oversaturation during heavy rainfall.
By selectively draining before and during a heavy rainfall, you can probably minimize water damage without drying out the ground too much.
One of our neighbors had foundation problems because his soil dried out during the dry spell we had in Houston a while back. His house was splitting in half and they had to do foundation repair.
My house is built up a foot or two above street level. The front yard slopes nicely out to the street. Unfortunately the deck slopes towards the house (doh!).
Needless to say, Houston climate and soil conditions are very challenging for homeowners.
I had to pier my house in Katy, and they found piers the previous owner installed while doing the job. My house in Cypress started showing signs after 10 years, brought out an engineer and they said it was still within limits. So far my house in Spring is doing fine, but you know the drill. It's not if, it's when. The trick is to never let it get so bad the slab opens up. Gotta watch those expansion joints in the brick, they're kinda your early warning indicator.
How did the new drains look with yesterday's rain?
If it's filled with mortar I'd question why. The joint should be filled with a foam backer rod and sealed with polyurethane or silicone caulk to allow normal movement with thermal expansion. It might mean there was enough movement to pull the caulk away. It does look like the top is opening up while the bottom is still closed. That's the typical sign the slab is starting to move, so you may want to see if you can bring out a foundation repair company that will do a free evaluation. The process is pretty simple, they diagram the house and walk a water level around inside the perimeter to measure deflection from the mid-point of the house.
Hairline cracks in the tiles are another indicator, but as long as they stay closed they aren't anything to really worry about. You typically don't need to remedy until you see cracks in the slab open up an 1/8", or become unlevel. This house had a couple of those tiny hairline cracks in the tile too, but we had the slab measured during the inspection and everything was within 1/4" corner to corner. We pulled up the entire first floor tile during our remodel this year, and didn't find any cracks in the slab in those areas where the tile had cracked. So sometimes it is just the tile and nothing with the slab. Speaking of flooring, we installed wood look porcelain throughout the first floor and it looks great. Doesn't matter if it gets wet, very nice when we have people going in and out from the pool.
Looking at the photo again, I'm curious why the joint doesn't extend through that top row of bricks. Looks like it cracked through the mortar one brick to the left? I'm no expert on how brickwork is done, but going by the three houses I've owned in the area over the past 20-something years, the joints always ran clear to the soffit or Hardiplank.
